Please help, I cant find a mech. that knows anything. 2002 duramax will start but run out of fuel after 10 seconds. happens when truck sits for more that 2 hours and has less than 1/2 tank. The primer will get it started again and than it runs. Just had the fuel sending unit replaced.
Thanks
sounds like you have air coming in somewhere
did you check around your FF esp the WIF sensor?
they're usually good for a leak :)
your FF head unit may also be leaking
rebuild kits are cheap and take 20 mins
x2 on an air leak kind of hard to see since the pump sucks from the tank to the motor, could be a fuel line but most likely fuel filter head or wif sensor
Also check the plastic bleeder screw, could have a crack in the plastic allowing it to suck air. Vendors here have billet replacements for pretty cheap..
