Thought I would get some advice from the RV trailer guys here. I want to add a small roof A/C unit to the dressing room on my 8 horse trailer. Lots of different brands to choose from. Are these things reliable or maintenance pigs?
I am installing a 30 amp service in the trailer now but don't need any 12 VDC so no converters or inverters needed. Wife just want a couple of plugs and an A/C unit with heater if available.
Is the rood installation pretty straight forward and usually water tight?
Do the roof units come with the inside ceiling control/vent panels?
My trailer has a 4 ft. shortwall so its a small area to cool or heat but it isn't insulated. We weren't going to use it except for storage for the shows but situation has changed so she is going to sleep in it.
Any ideas or advice will be greatly appreciated.
I've never done one from scratch but I don't think the installation is very complicated. A couple of notes:
1) Most RV roofs are "high crown" and the AC units are installed in the middle, at the highest point. As such, the AC-roof interface doesn't really need to be that watertight (it's usually just a big fat foam gasket) because water will naturally flow away from it. If you're doing this on a flat roof I would definitely shim the AC above the roof and ensure that the shim-roof interface is completely waterproof, so any standing water (the weight of the AC may create a very slight "dip" in the roof) will not enter the living space or ceiling.
2) I am almost -- although not completely -- certain that you will need a 12 VDC supply to make the thermostat work. Your amperage will be nominally zero, though, so this should be cheap to implement.
3) Relating to (2), I don't know of any units that can be controlled directly (i.e. without thermostat), but maybe there are some out there. You can definitely get non-ducted airflow, though (which is what you want since there is no ductwork). Cooling capacities less than 13k BTU/hr are out there but probably not very common.
4) As far as reliability goes, the 13.5k BTU/hr one that came with my old TT failed and I replaced it with a 15k that ran for years. The 15k one on my FW (it has a 13.5k in front and a 15k in back) didn't work when I got it home from the dealer; it had some loose spade connectors that just needed to be crimped down to make better contact. I think most of this RV stuff is garbage that runs on fumes and the aptitude of owners for troubleshooting.
5) For insulation, maybe consider the spray foam stuff. Probably worth it if you're trying to control the temperature.
6) Some of these units come with heat pumps which will have efficiency > 1 when the temperature is down to the 40s or so, but will have efficiency < 1 when it gets colder than that. Then there are some that actually have resistive heaters, which have efficiency of exactly 1 all the time. I don't know what's right for your situation but a small plug-in resistive heater is easy to throw in there separately, so I'd probably go with the heat pump option.
7) If you intend to run this thing off a generator you may need a "soft start" device depending on the generator's wattage. Due to high inrush current requirements a 15k AC will need at least a 3kw generator unless it has a soft start (even though continuous wattage is only ~1.5kw).
8) I don't know what the roof structure is like on your trailer; make sure it's capable of supporting the physical load of ~100 lbs.
Good luck and let's see some pics of your solution once it's implemented!
