I have one on order... The selling point for me was the use of a new GM OEM sending unit so the tank volume always is correct on the fuel gauge...
Same here ...keep us posted. I was going to make this mod, however I have heard mixed comments on the results. Would like to know how your gage reads, as well as any other issues that may result.
That would be great if the 2020+ does that too. With an approximate 1200 mile range, it'll take me a little while to run through a few tanks unless we're towing!I believe that's only on the first couple of fill ups. The computer will learn the new 1/4, 1/2, 3/4 & full miles after several cycles. I guess I'll find out after my install in a couple of weeks...
Keep us posted. I’m very curious to know if it will relearn.I believe that's only on the first couple of fill ups. The computer will learn the new 1/4, 1/2, 3/4 & full miles after several cycles. I guess I'll find out after my install in a couple of weeks...
It'll sure be easier to add the Schaeffer fuel treatment since their ratio is 16oz/125gal or 8oz/62gal...
True but at least you won’t be stuck buying overpriced fuel. Diesel is about $2.50 a gallon here in Texas and only goes up the further west I travel.The down side is now the Mrs. will want/need to stop every couple of hours...
My tank was delivery yesterday despite the backorder status. It is an impressive piece and seems worthy of the S&B reputation.I ordered the tank today from S&B. It's on backorder, but at least this gets my a spot in line. No indication how long the tank is expected to be on backorder.
Any report on gauge functionality yet?Finally had time to get to the tank installed today. Did it at home with the rear of the truck up on jack stands. With the help of my good buddy, we were able to get it done without any major problems - except I did damage one of the clips on the supply fuel line. I found a nearby dealer that had the line in stock and my wife ran to pick it up for me. Not a big deal at all, really. And despite the cost of the replacement line, I’m still way ahead of paying a shop to install the tank.
The tank is a tight fit - S & B really used as much space as they could. I was also happy that it still cleared the Air Lift air bag too.
It’s a 2 person job and it’s not hard. Some parts are awkward, but you come up with creative ways to remove the old and install the new.
Anyway, it really doesn’t hang down much lower than stock. Maybe 1” or 1.5”?
Here’s a picture of the completed install.
