#SecretSquirrel
:helpHey guys i just installed an S&B intake and it seem that 1st gear seems weak now.. only 1st though? i have a superchips on it for now i was wondering if its not spooling up fast enough beacuse of the stock exhaust? any thing u can tell me will help.. and also if i sit in park and rev the truck to 3-3500 the waste gate dose not move is this normal? :help :help
Received a Hummer
All I can tell you is, putting an intake on and not opening the exhaust first really makes no sense.......it's like putting a bigger top on a funnel.....won't flow the fluid any faster. Also...is it an oiled filter? If so, check your MAF and see if it has oil on it, or maybe it got dirty.
#SecretSquirrel
also just installed it about 2 hours ago
Received a Hummer
I would def. check the MAF sensor to see if there is oil/dirt on it.....if not, try putting the stock box back on and see if the problem goes away.....if it does, then I would wait until you can do an exhaust first..
