1 - 11 of 11 Posts
I have Toyo 305/40/22 114V proxes on an 09 2500. I’m wondering if it’s safe to pull a camper with these?
Ive towed around 6k with 305/50/20. I've seen/know guys who have towed a gooseneck with a pulling truck loaded on it with the same. It depends on how big your camper is and how far you're going really.
I’d def check the rating of the tires and the wheels and compare to what you’d be carrying.
Load range 114 is what is killing you, that is like 1,000lbs less per tire than stock.
LHN...We ARE the Joneses
Tire Neutered Dmax hauler. :teehee
305/50/20 is 3150 per corner iirc. Not sure about the 40/22
I wouldn’t suggest hauling pretty much anything, with your tires you’d have only about 2,000 lbs available to carry.
MAX LOAD SINGLE / DUAL (LBS.)2601 / -
MAX PRESSURE SINGLE / DUAL (PSI)50 / -
2601 X 4 = 10,404 total max weight on your truck.
You’d be safer with thick rubber bands for tires.
They’re for show not hauling.
I always joked that my lly had Tow/Haul Ass mode
I was referring to 22's being more for show not work.:wink2:
I have Nitto Ridge Grapplers 295-55R20 3415 per tire, I can haul weight and go fast, but at my age that probably wouldn't be wise, not quick enough anymore.
I have mudish tire on mine right now. They ride well but are a tad loud but I didnt get stuck this wet ass winter in the pastures or hunting. The 420s or proxes st come out for racing or summer time as I need the traction and tired of the humming lol
1 - 11 of 11 Posts
