1 - 20 of 33 Posts
The Good Son!
Since everybody wants to hammer the newbie’s for not using the search button (that doesn’t work), I have taken upon myself to go through and edit the tags on threads. By editing the tags the search button will work much more efficiently. I will try to keep a running list of search words and post it when complete. I’m thinking of mostly sticking with the 911 forum where most question and answers can be found. I currently have lots of time on my hands so, we will see how far I get...pretty boring to do.:drink
Search Button Help!
AC hot/cold http://www.duramaxforum.com/forum/tags/ac hot/cold.html
AC problems http://www.duramaxforum.com/forum/tags/ac problems.html
Bad injectors http://www.duramaxforum.com/forum/tags/bad injectors.html
Banks http://www.duramaxforum.com/forum/tags/banks.html
Body problems http://www.duramaxforum.com/forum/tags/body problems.html
Brakes http://www.duramaxforum.com/forum/tags/brakes.html
CP3 http://www.duramaxforum.com/forum/tags/cp3.html
Drivetrain (everything except engine and transmission) http://www.duramaxforum.com/forum/tags/drivetrain.html
DSP5 http://www.duramaxforum.com/forum/tags/dsp5.html
DTC error codes http://www.duramaxforum.com/forum/tags/dtc error codes.html
Dual tanks http://www.duramaxforum.com/forum/tags/dual tanks.html
ECM http://www.duramaxforum.com/forum/tags/ecm.html
Edge http://www.duramaxforum.com/forum/tags/edge.html
EFILive http://www.duramaxforum.com/forum/tags/efilive.html
EGR http://www.duramaxforum.com/forum/tags/egr.html
Electrical problems http://www.duramaxforum.com/forum/tags/electrical problems.html
Engine(engine, waste gate) http://www.duramaxforum.com/forum/tags/engine.html
Engine smokes http://www.duramaxforum.com/forum/tags/engine smokes.html
Engine Surging http://www.duramaxforum.com/forum/tags/engine surging.html
Exhaust, Exhaust installation http://www.duramaxforum.com/forum/tags/exhaust.html
FPRV http://www.duramaxforum.com/forum/tags/fprv.html
Fuel/Fuel additives discussion: http://www.duramaxforum.com/forum/tags/fuel additives discussion.html
Biodiesel http://www.duramaxforum.com/forum/tags/biodiesel.html
Diesel fuel http://www.duramaxforum.com/forum/tags/diesel fuel.html
Jet A1 http://www.duramaxforum.com/forum/tags/jet fuel a1.html
Kerosene http://www.duramaxforum.com/forum/tags/kerosene.html
Off road Diesel http://www.duramaxforum.com/forum/tags/off road diesel.html
2stroke oil http://www.duramaxforum.com/forum/tags/fuel additives 2stroke.html
BG http://www.duramaxforum.com/forum/tags/fuel additives bg.html
DSG http://www.duramaxforum.com/forum/tags/fuel additives dsg.html
Lucas http://www.duramaxforum.com/forum/tags/fuel additives lucas.html
Marvel Mystery http://www.duramaxforum.com/forum/tags/fuel additives marvel m.html
Mineral oil http://www.duramaxforum.com/forum/tags/fuel additives mineral o.html
Monster Diesel http://www.duramaxforum.com/forum/tags/fuel additives monster d.html
Opti-Lube http://www.duramaxforum.com/forum/tags/fuel additives opti lube.html
Power Services http://www.duramaxforum.com/forum/tags/fuel additives ps.html
RBP http://www.duramaxforum.com/forum/tags/fuel additives rbp.html
Seafoam http://www.duramaxforum.com/forum/tags/fuel additives seafoam.html
Stanadyne http://www.duramaxforum.com/forum/tags/fuel additives stanadyne.html
Used motor oil http://www.duramaxforum.com/forum/tags/fuel additives used oil.html
XDP Diesel http://www.duramaxforum.com/forum/tags/fuel additives xdp diesel.html
Z Max http://www.duramaxforum.com/forum/tags/fuel additives zmax.html
Fuel mileage http://www.duramaxforum.com/forum/tags/fuel mileage.html
Fuel system problems http://www.duramaxforum.com/forum/tags/fuel system problems.html
Gas in fuel http://www.duramaxforum.com/forum/tags/gas in fuel.html
HID's http://www.duramaxforum.com/forum/tags/hids.html
Ignition, will not start http://www.duramaxforum.com/forum/tags/ignition.html
Injector pump http://www.duramaxforum.com/forum/tags/injector pump.html
Injector wire harness http://www.duramaxforum.com/forum/tags/inj wire harness.html
Interior problems http://www.duramaxforum.com/forum/tags/interior problems.html
Leak, Leaking (any and all fluids) http://www.duramaxforum.com/forum/tags/leak.html
Limp mode http://www.duramaxforum.com/forum/tags/limp mode.html
MAFS http://www.duramaxforum.com/forum/tags/mafs.html
NBSU http://www.duramaxforum.com/forum/tags/nbsu.html
Oil pressure http://www.duramaxforum.com/forum/tags/oil pressure.html
Overheating http://www.duramaxforum.com/forum/tags/overheating.html
PPE http://www.duramaxforum.com/forum/tags/ppe.html
Quadzilla http://www.duramaxforum.com/forum/tags/quadzilla.html
Reduced power http://www.duramaxforum.com/forum/tags/reduced power.html
Rims http://www.duramaxforum.com/forum/tags/rims.html
Running rough http://www.duramaxforum.com/forum/tags/running rough.html
Steering http://www.duramaxforum.com/forum/tags/steering.html
Suspension http://www.duramaxforum.com/forum/tags/suspension.html
Ticking noise http://www.duramaxforum.com/forum/tags/ticking noise.html
Tires http://www.duramaxforum.com/forum/tags/tires.html
Transgo jr (All questions including install) http://www.duramaxforum.com/forum/tags/transgo jr.html
Transmission fluid discussion http://www.duramaxforum.com/forum/tags/atf discussion.html
Transmission problems http://www.duramaxforum.com/forum/tags/transmission problems.html
Turbocharger http://www.duramaxforum.com/forum/tags/turbo.html
Will not stay running http://www.duramaxforum.com/forum/tags/will not stay running.html
tagged to help out! Lol
saw what you did there
I've been re-editing thread titles to make the good threads easier to find via the search button.
Mighty white of you, you're a good man :rockin. I'd help if I could, but with my limited knowledge, I'd prolly just make things worse
The Good Son!
Discussion Starter #6 (Edited)
Wow, I can feel the love from looking at the tags!.....killer douchbag????
Ok Ok Brian !!
We get it .. You wanna become part of the staff.. I'm sure they will have a trustee postion open soon !!
Just F-IN with ya !! Nice job.. I too hated to use the seach option cause it never works..
I mean you seach for "programmers" and you get stuff like "goat sex" .. lol :rof
^^ OH.. So your the " goat sex" tagger... :rof
The Good Son!
Discussion Starter #13 (Edited)
I don't want to be part of the staff but, for us to tell people new to the site to search before asking a question is stupid. First off they are new here and probably don't even know where to search. The only thing more annoying than reading the same questions is some jackass (and you know who you are) constantly telling people to do a search. The search button only works efficiently if there are tags from my experience. So I have lots of time on my hands instead of telling people to search I figured I would try to contribute to the site for payment for all I have learned here. It is going to take some time though to get it setup.
Goat sex......... Where? I wanna see :D Just kidding, not my style :rof
I don't want to be part of the staff but, for us to tell people new to the site to search before asking is a question stupid. First off they are new here and probably don't even know where to search. The only thing more annoying then reading the same questions is some jackass (and you know who you are) constantly telling people to do a search. The search button only works efficiently if there are tags from my experience. So I have lots of time on my hands instead of telling people to search I figured I would try to contribute to the site for payment for all I have learned here. It is going to take some time though to get it setup.
I agree !! Some are a bit harsh on the newbee's... But your right, why be an ass and send them to the search page, when the search page (to me) does not work all that well...:rockin
:rof:rof:rof
Hey Ass Man!
Nice job! Too much time on your hands??:confused:
1 - 20 of 33 Posts
