1 - 2 of 2 Posts
some of you may have saw this already on truckpulls.com, just thought i would pass it on. from what i have heard there will be a good turnout
his will be an ALL DIESEL pull on Sept. 29 at the Muskingum County fairgrounds sponsored by New Era Diesel Performance. There will be 3 classes. Although rules will be somewhat lax, NO DRUGS will be permitted. (NOS,propane ect) Water Meth WILL be permitted in ALL classes. If turning over 4K blanket is needed. Loops are highly reccomended. The top 5 trucks from street and super street WILL BE teched. Those that feel their drugs are well hidden...gettem off there for this pull...you know who you are...and so do we. Hook fee will be $25. Please remember, this purse as of 7-17-07 is for sure. The more pullers and sponsors that sign up, will deffinately increase the CHANCE that the purse will go up. I will check to be sure but I understand there are some HUGE sponsors there like Valvoline,Edge,Diesel Power magizine to name a few.
Street Class
2.5 max charger
Payout is $500/$400/$300/$200/$100
Top 5 trucks ARE PERMITTED to advance to Super Street
Super Street
2.8 max charger (changed to 3.0)
Payout is $1000/$800/$600/$400/$200
Top 5 trucks ARE PERMITTED to advance Modified (open class) after passing inspection
All I can say is you had BETTER BRING IT!!!
Complete rules will be posted in a while. Again, they will be somewhat laxed, but pretty much all safety rules apply,ESPECIALLY those turning over 4K. Again, NO DRUGS!!! Iwill try to answer / get answers to questions as needed. Thanks _Smokes
__________________
WE WILL BE HAVING A BIG PULL ON SEPT.29TH AT THE MUSKINGUM COUNTY FAIRGROUNDS. THERE ARE ALOT OF BIG SPONSORS ON BOARD FOR THIS PULL. WE WILL BE HAVING A FEW GIVEAWAYS THERE WILL BE PLENTY OF SMOKE AND SOME GREAT FOOD.
CLASSES: 8000 STREET, 8000 SUPERSTREET, 8000 OPEN.
HOT FARM, AND PRO STOCK TRACTOR CLASSES.
THERE IS 7500.00 UP FOR GRABS IN THE PICKUP CLASSES.
FOOD WILL BE PROVIDED BY THE MUSKINGUM COUNTY CATTLEMENS ASSOC.
GATES OPEN AT 2PM, TECH STARTS AT 3PM, PULLS START AT 5PM.
STAY TUNED FOR MORE INFO OR CALL 740-819-0457
RULES FOR THE DIESEL TRUCK CLASSES
STREET CLASS
1. ALL TRUCKS WHO PLACE IN THE MONEY WILL BE TECHED!
2. 8000 lb Dual Rear Wheels Allowed
3. No Nitrous, Propane, Alcohol, etc. #2 Diesel Only
4. Water Injection
5. Hanging weights allowed, furthest point must not exceed 60” from C/L of front axle
All weights must be secure; disqualification may be enforced if weights fall off.
6. Must have full interior, exterior. Has to remain street legal
7. Must provide license and registration
8. Single Charger only limited to maximum of 2.5” wheel. Reducers, plugs, etc. can be used to make a large wheel charger “fit” into this class. Chargers will be teched.
9. DOT tires, no studs, no cut or sharpened tires.
10. No aftermarket transfer cases or transmissions.
11. Rear suspension must have a minimum of 1” of travel.
12. Must pull from Reese style hitch or factory bumper. Hook point must be at the furthest most point of the vehicle. Hook point must be at least a 3” OD ring or clevis.
13. 26” Hitch Height
14. Traction/ Ladder bars allowed
15. Exhaust must exit straight up or straight down- No exceptions.
16. Puller will be allowed a total of two attempts within the 100 foot mark to start the sled. Test puller may drop and come back in sixth position.
17. Engine must be out of factory 1 ton or smaller pickup
18. Bellhousing blankets required for engine turning over 4200 RPM.
19. Rear U-joint shields required. Driveshaft loops highly recommended
20. Track and Tech official’s decisions are FINAL
SUPER STREET
1. ALL TRUCKS WHO PLACE IN THE CLASS WILL BE TECHED!
2. 8000lb limit (Dual rear wheels allowed)
3. No Nitrous, Propane, Alcohol allowed. #2 Diesel Only
3. Hanging weights allowed, furthest point must not exceed 60” from C/L of front axle
4. Single charger class with max. 3.0 wheel.
5. DOT tires, no studs, no cut or sharpened tires.
6. No aftermarket transfer cases or transmissions i.e. Dropboxes, Reversers
7. Factory rear suspension may be blocked, no custom rigid suspensions allowed.
8. Hitches: Reese style hitch, factory bumper or under bed hitch. Hook point must be 48” from the centerline of the rear axle. Hook point must be at least a 3” OD ring or clevis.
9. 26” Hitch Height
10. Traction/ Ladder bars allowed
11. Exhaust must exit straight up or straight down
12. 4500 RPM limit.
13. Engine must be out of factory 1 ton or smaller pickup
14. Trucks that place for the payout will be teched (to be determined)
15. Bellhousing blankets required for trucks that do not meet the Street Stock rules (over 4200rpm)
16. Driveshaft loops required for trucks that do not meet the Street Stock rules (if your in this class you should have loops)
17. Water Injection permitted
18. Fire Extinguishers required
19. Injection pump must be stock appearing (for example: No Ag governor on P Pump). Dual CP3 pumps allowed.
20. Track and Tech official’s decisions are FINAL.
8000LB. OPEN CLASS
1. 8000 lb
2. Diesel only
3. 4X4 Truck
4. 26” Hitch Height
5. Blow proof bell housing or blanket, kill switch, driveshaft loops, exhaust must exit up or down, helmet.
6. Track and Tech official decisions are FINAL.
ANY QUESTIONS PLEASE CALL 740-819-0457.
AS FOR THE GAS CLASS IT IS A 6500LB PROSTOCK CLASS. PLEASE CALL WITH ANY QUESTIONS ON IT AND I WILL GET YOU THE ANSWER. WE ARE RUNNING THIS CLASS AS A FAVOR AND HAVE NOT BEEN GIVING THE RULES FOR IT AT THIS TIME.
Discussion Starter · #2 ·
i saw this today i case anyone is interested
Ok guys here is the hotel stuff.
Baymont Inn and Suites
230 Scenic Crest Drive
Zanesville, OH. 43701
Tell them your here for the truck pull on the 29th for a discount.
Wolfie's Family Kamping
101 Buckeye Drive
Still working on a diescount for the campground but thier rates are good anyway. Full hookups and internet.
Both places are about 5 mins from the fairgrounds. Thre are other hotels in the area but baymont is the only one that would make a deal unless we booked the rooms then sold them in blocks.
1 - 2 of 2 Posts
