2008 chevy 2500hd 6.6lmm
every time i start the truck for the past month i get service trailer brake message on dash.
I have replaced the trailer brake control module,relay,brake light switch and trailer gain switch. All oem parts
i have checked all wiring and connections. Any suggestions? Thank you
Is your gain switch fully seated in the dash?
My 2013 switch was slightly loose and gave me the same message. Added a bead of RTV when I reinstalled it... no more issues
Could also be a bad wheel speed sensor or from what I’ve read a bad BCM. I found out about the speed sensor when I changed a bearing hub out. My truck is the new body style and the parts store gave me one for the classic. Took a while to figure that one out. I went through the parts change out like you, before finding that out. Could have saved some money.
Reactions: RobStef655
What puzzles me is i don't have any abs codes
I don’t think I had any either. Could possibly be a loose or cut sensor wire. Just throwing ideas out. There’s several codes that are tied into the Service Trailer Brake message.
Sent from my iPad using Tapatalk Pro
