1 - 2 of 2 Posts
I'm proud owner of the 2006 GMC Kodiak 6.6 DuraMax 4x4, 21,435.8 miles on the odometer.
As I pull away from stop, pulling 12,550 lbs. up a slight grade, the truck shakes, rattles and rock & rolls..so much so, the cargo bed shakes too. once in second gear smooth.
Alison replaced the 1000 transmission as the transmission temp increased during the maneuver;
Transfer case opened & inspected. No issue there.
Checked alignment of the drive shafts. Perfect.
Engine Temp okay.
Could it be the turbine wheel causing the turbo lag/surge?
No modification to EMS; all stock.
Ideas?
Thanks
1 - 2 of 2 Posts
