1 - 8 of 8 Posts
with truck not running ….turn key on try moving shifter
put in neutral and start truck
What year truck? I'm on my phone and can't see details?
Could be junk shifter cable... Relatively easy to replace if it is...
It is a 2006 with a lbz. Yes it is running.
shut it down... then put key to on ,,,, do not start
depress brake …
try shifting to neutral ….turn key and start truck
It does the same thing in the on position also. I know is a fly by wire system. The shifter dont move when the truck is off. But once u turn it to the acc, on or start position and press the brake the shifter moves but does not come out of park.
Have you slid under and had someone move the shift lever to see if one of the cables is broken? (don't get ran over!!!)
Thanks guys found the problem clip fell off the linkage hooking the cable to the transmission. Have to get another clip. For now I am going to safety wire it
1 - 8 of 8 Posts
