1 - 14 of 14 Posts
Logged my injector balance rates with my V2 today.
Drove it around and got it warmed up and logged the rates in park.
here are the results
Inj#1 0.92
Inj#2 1.53
Inj#3 0.67
Inj#4 0.81
Inj#5 0.22
Inj#6 2.02
Inj#7 -3.89
Inj#8 -1.94
Injector 7 is scaring me...
should i keep monitoring it until it gets up above +/- 4???
Thanks
Are you having any fuel dilution in your oil?
Have you run any injector cleaner additives in your fuel?
when was last time you changed your fuel filter?
How did you check your Balance rates in park or D with brakes on?
I haven't done the fuel in oil test in like 8k miles. Need to do it again.
I havent ran any injector cleaner in fuel.. any suggestions??
I changed my fuel filter about 7500 miles ago. (racor)
I checked my balance rats in park.
Ok
Do the fuel in oil test, if it is ok
Change your fuel filter
Run a couple tank with about 6-8 oz of diesel Kleen in th gray bottle in it,
then after a tank or two of running the diesel Kleen check them again.
I run diesel Kleen in every other tank (about 4-6oz) every other tank.
I have read people say every other tank run an injector cleaner with some kind of additive to increase lubricity, also I have heard a lift pump will drastically increase your life on the sticks (one that removes the air bubbles from the fuel, like an Air Dog II my next investment)
I run diesel kleen maybe every other tank. (whenever i remember to put it in there)
I thought you meant some special fuel injector cleaner.
it is getting about time to change my fuel filter. gotta place an order sometime this week for one.
do a heavier dose of DK in a couple of tanks consecutively after changing your fuel filter
good deal bro, then check your balance rates, if that doesn't help there is a thread on here in the DIY about injector cleaning I would try it, several have done it and it brought their balance rates back well within comfortable readings
Banned
Check them in stock tune..............
MudDoc- I read that thread about the DIY injector cleaning earlier this month. seems pretty simple.
SmokingLMM- I can't remember what tune i was in. But i will try it in stock next time.
Another question...
I'm still not sure if i installed my DSP5 switch correctly. I feel like I should tell more difference between my stock tune and my 100hp tune..
Isnt there a way to check with my V2 if my tunes are switching properly?
you can, but also TDFDiesel can help you out or several others with DSP5 switch questions
Banned
Another question...
Yes, do a log and select the pid for dsp5 voltage and then see if it changes with the switch.
1 - 14 of 14 Posts
