1 - 7 of 7 Posts
Well winter is almost here. Snowing in the mountains!!! Finally!!!
It is my first winter witha diesel and i am a little concerned.
I know it is better for them to be warm bfore driving. I only live a little under 5 miles from my work. Am i going to kill the truck by 7 days a week starting it up letting it warm fro 5-10 minutes and then driving 5 miles and shuting her off??
I will be going up to the mountains once a week so it will get a good run.
Also is there anythig i need to do before winter?? i have thought about a winter grille cover. good? bad? ???
Administrator
synthetic oil, grille cover, and fuel additive.
driving that short will not be very good on the truck, just make sure to get it good and hot a few times. these trucks like to be worked.
Got it. thanks.
Where can i get a grille cover?? i have tried to google it and cant find the right one.
Any fuel additive better for winter?
Not trying to steal the thread, but this will also be my first winter, and it gets cold here, typically in the 20's during winter. Is it a good idea to plug it in?
Read your owner's manual. GM doesn't recommend you plug it in until below 0 F. But it won't hurt anything to plug it in if its warmer than that. 20s is nothing, it will start right up like a gas engine every time.
Administrator
The grille cover can be bought on ebay or if you want aftermarket ones cabelas sells one that is thicker & quilted. They also have one that has a screen for the summer. I was searching for stuff for my topper the other night & came across one just like in cabelas & it came with the screen for the summer for like $35 or so.
As far as plugging in, I do it at 15 above or colder when at work. The newer trucks might throw codes if you do it at that warm...but it definately helps on warm-up.
Products this is what me and a couple buddies run... haevn't tried out the winter blend but i like the summer blend a lot
1 - 7 of 7 Posts
