1 - 13 of 13 Posts
Banned
I was wondering if anyone noticed a different ride when they got to a bigger rim or heavier ply?
It might be me but I went to a 17 from a 16 and got a 10ply from a 8ply. Seems alot rougher going down the road now? Or might be me :rolleyes:
Yea I went from a 17 to a 19.5 with a 12 ply tire and the ride was horrible for a wial. Took a trip to vegas to make them good. On my 10 ply 17s I ran 70psi in the from and 65 in the rear. What do you have yours set at?
Banned
I have them set at 60 all way around. The tire recommends 80 :rolleyes:
Most likely it's just the 10 ply and the wheel size, you've got a double whammy there. You'll get use to it. It'll be a lot safer and fell more stable while towing. What kind of tires did you get?
Banned
:rof Thats what I figured!
I went with the Nitto Terra grappler again. Its a decent tire :rockin
I was thinking the same thing....I'm replacing my stock 245 with a set of 305's on H2 rims. I'm pretty sure the ride will be a bit rougher....
Banned
You will have alot more side wall... Yours might be better! What ply are you going with?
I will have to check the recommendations....The Toy Hauler that I will be towing will weigh approx 10K loaded (5th Wheel).
Is that running empty? I found that with my trucks and using "E" load rated tires that about 45 - 50psi in the rear and 55psi in the front when unloaded gave the best wear characteristics and also a better ride. When hauling heavy, the fronts get 70-75 and the rear gets 75-80.
My trucks include:
1997 GMC K2500 4x4, EC/LB (8600 GVW model) roling on 235/85-16 "E" rated Mud King XTs. This is now my hunting/work truck.
2009 Chevy 3500HD SRW, 4x4, EC/LB roling on 265/70-17 "E" rated factory installed tires.
I use the same tire pressures system in both trucks.
I usually run my tires at 50-55 in town and inflate them to the recomended pressure when doing a lot of highway driving. It does help the mileage on the road.
I went from 265/70/17 goodyear wrangler E rated 10ply that were rougher than hell to 285/65/18. These new trail grapplers are quiet and ride much smoother over nasty heaves in the road. They too are E rated 10 ply but more rubber made a difference. I run 55 in front and 50 in rears. Would love to hear what others are running trail grapplers at. My bro run a 35 inch D rated tire on his cummins and loves the smoother ride over E rated tires hes had before. You give up a lot when hauling heavy load tho.
Banned
Good idea guys! They dont flaten out on the bottom at all. Ill probably drop it down to 50 since I dont tow alot. If I do I usually know ahead of time and then I can bump it up a few pounds :cool:
1 - 13 of 13 Posts
