Im having a problem when i take left turns from a stop with my truck. When i take a decently wide left turn like at a medium size intersection when it goes to shift it feels like it goes into neutral then rev up and slam into the next gear. i can feel when its going to happen so i can let of the throttle and it wont slam bad and it also only happens when the tranny is cold
VAGITARIAN :)
Check to be sure you have the correct amount of trans fluid!How long since trans fluid was changed?if you've never done it,now may be a good time to change fluid and get a fresh spin on filter on it....
I checked my fluid when it first happend and it was good. i checked it in the morning when it was cold but will check it when its warm. also doesnt looked burnt and doesnt smell. i was planning on doing a tranny fluid and filter change next oil change which is soon so hopefully that will help
