I was reading a thread showing how you need to know your fuel rate with your balance rates in order to get a true reading of your balance rates. He was saying that your fuel rate SHOULD be around 8 MM3. Well I only have the ability to get a fuel rate in gallons per minute. When I convert my gallons per minute to MM3 I get a number like 75,000 MM3. What on earth am I doing wrong? I need to see which injectors are bad.
You need to check the return rates of the injectors, as in connecting a line to each injector and measuring the amount returned when it is running. A very involved job. Search for "how to check return rates"
