There have been a few questions as to what the SPADE is and how it relates to the AutoCal. Here’s a quick explanation to hopefully clear things up.
AutoCal + Tuning from Nick at Duramaxtuner = SPADE
Basically the SPADE unit is the combination of the AutoCal devise and Tuning from Nick at Duramaxtuner. Why call it the SPADE and not an AutoCal that was tuned by Nick at Duramaxtuner? One reason is because it’s easier to say SPADE than “An AutoCal that was tuned by Nick at Duramaxtuner”. I hope that helps.
-Scott
Question- If one were to buy a Spade and later down the road add a turbo/injectors ect ect, can it be reprogrammed for these modifications?
The same rules apply as with the AutoCal. You can have it reprogrammed, but it would have to come from the original tuner. In this case Nick. Great question, thanks for asking!
Per your order form, there is an area to describe other alterations? Is this where you can ask to turn off the "grid heater" check engine codes but leave the grid heater active when running an EGR delete pipe?
Thanks,
Nate
That is the best place. You can also give the office a call if you have any other specifics you want to discuss. Bob can help you out with any questions. Thanks for the post Nate.
-Scott
