1 - 14 of 14 Posts
Sometimes it works all day and other times it will quit after a few minutes of driving or idleing. Any thoughts on this? THANKS
stepper motors on the back of the cluster going bad
ya check into the stepper motors. there was a thread on here awhile back, but forget where it is. try searching for it
Ask one to be one
I fixed the one in my 04 be buying an aftermarket cluster from us speedo.
Man you guys are great!!!!!Thanks for the pictorial and easy directions LLYD MAX.
dealer fixed mine for free...04.5 also and my truck was out of warrenty, I believe it's a service bulliten or something like that.
Ask one to be one
You have to have under 70K on your truck for them to fix it for free.
no problem man! always glad to help. :drink
Did it all the way LLYD MAX said and when I put it back into the truck all the needles fell way below where I had set them after the tape process. Now how do I get them back to where they are supposed to be?
Can anyone help, please?
True, The bulletin says 75,000 miles but actually it's up to 85,000. That little bit of info cost me $400 as one of mine was just under 85,000 when I saw the TSB so, thinking it was too late I waited until it completely broke and had 89,000 on it... go figure :confused:
Some dealers will not fix it even tho there was a bulletin because there is some numbers in your vin that have the deciding factor in them replacing it for free. I had an 05' and mine was not covered under that bulletin
1 - 14 of 14 Posts
