So still having pressure issues after doing a coolant flush seeing if maybe a air bubble was causing it but guess not. My low coolant message hasn’t came back but the truck seems to be running cooler the temp here in bama has dropped but it’s hard to get the truck up to 210 on the dash gauge could it be thermostat issues? Causing the pressure over night and the lower temp reading?
Discussion Starter · #2 ·
Also I am not loosing any coolant I never see any one the ground and once I release pressure on the tank it fills right back up, will bad head gaskets cause me to loose coolant?
^this
If you haven't changed the res cap yet do it. You would be surprised how many times that 10 dollar cap has cost someone some big bucks. Also if its not getting to temp then yes change the thermostats
