ok so now what. i got my truck back, the slip says 8injkt rem, gaskets, coolant, fuel filter, oil, oilfilter. everything covered by warrantee. cost $0. ive driven the truck 50mi and there still appears to be fuel leaking from between the engine and tranny. it only seems to leak when the truck is running. if i park it and shut it off the spot left is only about the size of a baseball card. residual i assume. when its idling the spot will become the size of a greeting card in the matter of 3-5 min. and the smell of diesel could knock a buzzard off a shitwagon. i don't mind the smell so bad, but i don't want to smell like i've been on a tractor all day. something must still be wrong. could the pcv tube be clogged, turbo not working correctly, rear main seal shot, etc.. i'm taking the truck back to the dealership monday morning but is there anything i should be looking for in the meantime????
