1 - 16 of 16 Posts
i have a stupid fuck ing vibration that is driving me crazy that i cant find under the steering wheel. Im leterally ready to blow up my truck!!!!! It does it all the time especially when im on the highway or at a stopsign or light .... Any ideas what it could be and if anybody else has this problem !!!!!!!!!!!!
Banned
My LBZ used to vibrate from the panel under the steering wheel. There are 2 layers in it with a metal liner so pushing on it does nothing, take it off your truck and shoot full of some expanding foam. I bet your rattle goes away.
are u talking about the cover right below the steering wheel that is held on by 2 nuts
Banned
how about the good ol steering shaft replacement guys!
I had the same problem mine turned out to be the heat shiled under the dash there is a how to write up on it in the forum section DIYs and How toos
heat shield sorry
Banned
Just take the panel off and go for a ride.
Is it a clunk or an actual sound of something vibrating against something. All Chevy/GMC's from trucks to tahoes have the intermediate steering shaft (clunk/play) issue. Where everytime you hit a bump or come to a stop it feels/soundslike your steering shaft is loose.
Recall on the sterring shaft.... sorry to say, but we had ours done and it came back 5 miles later... i found on another forum about drilling into the shaft and shotting about 100 pumps of grease into it... solved the problem.... guy has running it for 4 yrs like that and not a bump/noise/vibration....
I will try to find it when i get home tonight
I'm not familiar w/how the steering column works, but I am w/grease. And grease breaks down and tends to liquify after excessive heat and time.
Discussion Starter · #15 ·
it actually clanks and shit when i hit a bump to almost like a bad hub and when i turn it like makes a noise to sometimes is there any way i can for sure tell the shaft is bad??? i am also taking the panel off now so well see how that goes
Discussion Starter · #16 ·
just looked for the diy about the heatshield found it about the nbs truck but not the obs truck
1 - 16 of 16 Posts
