1 - 7 of 7 Posts
Alright so I have a 4 hour trip coming up saturday so I changed the oil and fuel filter, now my truck wont start. im pretty sure it has something to due with the fuel system by the way it sounds while trying to turn over.
Any ideas on what should check or test? maybe a new filter housing? seems like it wont keep a prime after cranking or sitting for a while?
and sorry if im bad at typing or trying to get my point across, i hardly post but i read the forum constantly.
thanks guys
How long have you primed it? Does everything sound OK, like does it crank normal and just not start?
Yeah sounds fine when cranking
and i push till i cant budge it anymore.
Coffee addict
Stupid question but... Did you open the bleed screw to let the air out?
yeah got all the bubbles out of it
Coffee addict
The o-ring set right? Had that problem before, o-ring was crushed on the side, diesel was leaking while priming.
im not getting any fuel out while priming it so i dont think it would be that. ive pulled it off and put it one twice now
1 - 7 of 7 Posts
