About a month ago, my backup lights stay on randomly. Sometimes it stay on for days, sometimes it stay on for few minutes. I had to remove bulbs temporary to prevent draining the batteries. It happened around same time when the headliner took out for re-upholstery. I checked the fuse box under the hood, I pulled almost every fuse except TBC BAT that pointed to BCM. I was able to narrow down the specific fuse. It is driver side fuse box - TBC 2C 15A that turn off backup lights. Without TBC 2C fuse, I put gear in reverse - the backup lights turn on no issue so I know it is not backup light fuse under the hood. Can anyone chime in what TBC 2C actually do? TBC 2A and TBC 2B - The dome lights, cluster lights are working fine. Keyless system are working fine so I need to know where the actual wrings goes for TBC 2C. The fuse did NOT blow so I suspected something that trigger backup lights stay on. Does TBC-2C run same driver A pillar along with TBC-2A or 2B?
TBC 2C Fuse 15A Body Control Module (BCM)
