I'm having some problems with my Temp gauge, Battery gauge and Transmission Temp gauge
I replaced the stepper motors on all my gauges, even dough I only needed the speedometer, at first after putting everything back, all the gauges worked, but I noticed that once I turn the ignition off the needles were a little bit off, so I took everything apart again, fixed the needles then after I put everything back my battery gauge started acting up, the needle was all over the place, took it all apart again and replaced the stepper motor on that gauge for one of the old ones, put everything back and now the battery, temp stopped working and I'm not sure about the transmission temp.
Does anyone have any idea what the problem could be?
THanks
Check all of your solder points. The rest of the cluster works?
yes the other gauges work, but the weird part is that all of them worked, until I took it appart for the second and 3rd time.
