1 - 1 of 1 Posts
Vendor
The famous AeroBox is now available at CARiD.com. This incredible cargo box is designed to be mounted at the back of the truck bed for easy access from the backside with the tailgate open. It is rotational-molded from black linear low-density polyethylene and comes with a grained texture. The box sits below the truck rails meaning that the accessory can be used with almost any type of tonneau cover.
The AeroBox comes in two variants: Standard and Premium. The Standard modification features a truck bed floor mounting system. The box is designed to be locked easily into place. When it is not needed, it can be removed fairly quickly and rolled away into your garage, for example. The Premium package also includes side panel mounts for quick and secure installation, interior divider panels, and exterior tie-down rings.
AeroBox® ABSA02 - Standard Single Drop Door Rear Mounted Truck Bed Cargo Box
AeroBox® ABUA02 - Premium Single Drop Door Rear Mounted Truck Bed Cargo Box
Specifications:
Box Width: 58.5" (which is also the minimal tailgate opening)
Depth: 19"
Height: 19
Weight: 50 lbs.
Standard Features:
Integrated compartments for small items in the door
Door can be removed and used as a portable work surface
Seamless rotational molding construction
Recessed features on the top and back walls for securing long cargo in the bed
1/4 turn universal floor mount fasteners make securing your box to the truck an easy task
Decreases drag caused by the tailgate
Works with most tonneau covers and camper shells
Uses premium locks and existing tailgate security
Easily to remove and roll to a new location
Locks into place easily in a truck bed
Black grained texture
Made in the USA
+Premium Features:
Side panel mounts
Interior divider panels
Exterior tie down rings
If you have any questions, feel free to ask them here, in a personal message, or contact our sales team at 800.505.3274 (toll free)
1 - 1 of 1 Posts
