i gave'r today, and threw these to codes
P0401
P0087
i cleared the codes and they stayed off, but i want to make sure everything is ok?
i think the first code i remember somebody telling me its my egr and i should block it or something? can comeone shed some light on this wether i should or whatever and if i should ..how? lol.
and help on these codes? thanks
P0087 is low fuel rail pressure. you likely drained it on one of your higher tunes. do you have the fprv shimmed or a race plug installed? if yes, then its time for a lift pump. if you have both then you may need a cp3.(this one is doubtful, I'm sure you'll answer no to one of the earlier questions before getting this far)
P0401 is insufficient flow to the egr. I'd just block and fingerstick it if i were you/ and or delete the sucker. should fix your issue and be better for the engine.
so delete the egr?
and i dont think the fprv is shimmed and no race plug installed.
im getting rid of both iq and diablosport putting efi live in.
i shall search online on how to delete the egr thanks
