I have a 06 GMC crew cab with 4" lift will 35" tires fit. or what would be the best size tire and rim?
35" tires should fit on a 4" lift on the OBS trucks. The NBS trucks would need a 6" I would do a 9" wide rim for that size tire.
yes you should be able to fit 35's without any issues. depending on your wheels backspacing/offset you may have to trim the front bumper a bit
Supporting Vendor
Or if you want a size that is just smaller than a 35, look into a 295/70R18 Nitto trail Grappler.
This is a great size to run if you tow. These are about 34.5" tall and about 12" wide. LT295/70R18E has a 80psi max pressure. LT35X1250R18E will only have a 65psi max. If you tow often being able to run your tires at 80psi will really help the vehicles response and stability under load.
