1 - 9 of 9 Posts
I have a 6" Fabtech lift not cranked so cv angles are good, it just seems like there is way too much body roll when going around corners, what would help me fix this problem?
Of course you could remove the lift and that would help! Beyond that, you could change the shocks with heavy duty ones, and add aftermarket sway bars.
I just put the lift on like a few thousand miles ago lol..I don't have any stock parts anyways, I would have to buy new rear spacers and change a lot of things, would be more trouble than it's worth..I didn't know if trac bars do anything for corner roll on the hwy or if a rear and heavier front sway bar would do the trick..
How are your lower bump stops?? O just put new ones on my truck and it rides better than ever
Discussion Starter #6
I have brand new bump stops from Nick and I have 18x9 XD Monsters with 35/12.50 nitto trail grapplers..
BANNED
I would try sway bars.
Discussion Starter #8
any good brands? would I need a new front one or both front and rear?
X2 on the tire roll. New tires that size sway alot! With time they firm up a little. Idk about sway bars
1 - 9 of 9 Posts
