Hello guys, i'm new to the duramax community. I have a couple questions i'm hoping you all can give me some advice. I have a 2007 duramax 2500 classic crew cab short box. (LBZ motor). I use this truck to pull my 30' gooseneck trailer. I haul farm scrap loads ranging from 10,000 lbs up to possibly 25,000 lbs. (5-12.5 ton). Most loads are around 15,000 lbs. My trailer weighs around 7500 lbs alone. So long story short this truck is pulling some major weight. more than most which is why i decided to post this as a new thread. The back end sags somewhat but not as bad as a ford or dodge would.
It pulls the weight rather well. Some hills are a bit tough. My mileage is 8-9mpg loaded or unloaded. it doesnt seem to make a difference if my trailer is loaded or not loaded, (must have something to do with running with tow mode turned on) I'm usually hauling 6 days week. Typically burning a tank of fuel a day depending on how far of trips I make.
My question for you pros out there is what kind of mods would you recommend. My truck is currently stock. It has 101k on it. I'm not lookin to have a screamin loud exhuast or do burnouts. I just want to be efficient and get the job done. Many tell me to buy a chip, but i think most people running chips are only pulling 10-15k. So i'm wonding if chiping this truck would be hard on it because i'm pulling massive weight.
My other question is when carrying such heavy loads should I be running in D or M mode? Which is easier on the transmission. Of course i always leave the tow mode even with an empty trailer.
Any advice you guys can give me is greatly appreciated.
