We just traded in a 2013 3500 Silverado for a 2021 Denali 2500 to tow our 38 ft, 5th wheel toy hauler. The newer truck has more gears, driving mode selections, and features, so I would like to hear some opinions on driving in mountain grades.
With the 3500, I would slow to 50-55 at the top of 6-7% grades, manually drop into 3rd gear (6 spd trans) and let the exhaust brake limit the speed. However, there were a couple times on one particular downhill run that I only dropped down to 4th and the rig started climbing up over 60 mph, so I applied the brakes. When I did that, it felt like I blew a front tire - steering wheel shaking like crazy. Both times I pulled over at the bottom of the hill and checked the tires. Never any issue. I suspect the front anti-lock brakes were kicking in, causing the steering to shake while the back tires kept traction due to the weight of the fifth wheel.
The trailer weight, tongue weight, etc., are all within the Denali towing specs for 5th wheel.
1. What is the suggested way to approach that hill with the Denali (10-spd trans)?
2. This vehicle has "grade braking" (letting your foot off the brake after hitting desired speed). Is that better than manually down shifting as I am used to doing? Is that for mountain driving without a trailer, or something else?
3. This vehicle has 2WD, 4 H/L, and 4WD Auto selections. I'm assuming I should just leave that in 4WD Auto?
