Well next week I'm going on vacation towing a 20 foot car hauler with 6 ATV's on it i'm figuring everything will weight in at about 4000lb so pretty light.
I want max mileage out of the truck and the edge has a towing stage and a mileage stage. which one will i get better mileage with while towing?
in the manual it says u should tow on lvl 1, or tow light loads on lvl 2, dont know what they consider light though.
Smoke. It's what's cookin
I'd say 2. If it's the towing level then tow in 2. I guess it just depends on your truck and what it wants too. It might do better in 1 but I guess just try and see and go from there. I guess if you don't lead foot it, you'd be ok in 2.
Hi, I'm Earth. Have we met?
THe one thing about the juice is that u can set the egt limits to 1250 or so and set it defuel on shifts and heck u could tow on almost any level and not worry because it will take care of not hurting things!!! If i were you i would run level 3 and set the limits to defuel on 4-5 shifts and set egt limit to 1200 deg. and u should be good to go!
Awesome
Thanks for the info guys.
