1 - 9 of 9 Posts
Hi everyone,
My very first post on this site so bear with me. I have a 2011 2500HD. I am running a 7.5" lift with 37 " tires. The new tires (NITTO Terra Grapplers - Lt355/65R18) are a 50 PSI tire and the tires that were originally on the truck were, I believe 65 PSI tires. My question is the in dash monitor keeps saying pressure low, add air. Can the set point be changed to alert at say 45psi or am I going to have to live with this alert using these tires?
did you have the TPMS sensors put in your new wheels? If you can find a dealer willing to, or someone with a TECH II they can adjust the setting lower, not sure if it will let them go that low though...
Is there any way to shut the system off completely? It's annoying when I change my tires every six months.
yeah go to the dealer and have them change the set point. had mine set to 50 and haven't had a problem since.
not that I'm aware of. some people have stated they put all the sensors in a pvc or metal tube and pressurize it to what ever the set point is and throw it under the back seat but I don't see that working as they need to spin to "wake up" per say.
Thank You very much for the info.. I will call the dealership today.
Well I called 5 dealerships today. 2 of them said it cant be done, It is set from the factory.
1 never called me back and the other 2 said yes it can be done but they were not sure how low you can go for a setting. They both said that it is $95. to hook it up and change it. I set up an appointment so I will know next week.
Well, Here is my update...
I went to the dealership today about resetting the tpms.
I was told $95.00 to hook it up and make the change. When I pulled the truck into the service dept. one of the service writers came over to greet me and I told him that I needed the alert psi lowered because the new tires run 50 psi. He went over and grabbed a machine like a laptop and pushed a few buttons and set it to 45 psi. He unhooked it and said its done. No charge and took about 10 minutes from the time I arrived.
1 - 9 of 9 Posts
