Tran go shift kit
2178 Views 6 Replies 4 Participants Last post by  TurboBeagleBuggy
has any body used the trans go shift kit from sun coast. Does the tranny need to come out to install it
1 - 7 of 7 Posts
The trans-go kit is part of the Suncoast kit that I have in my transmission. You do have to take the trans out and disasemble part of it to put the trans-go kit in the pre 06 trucks as you have to drill and put restrictor valves in the C-2 clutch drum. While you are in there this far you might as well replace damaged clutches and upgrade your TC as well. There is a few more things coming soon that everyone should consider as they help clutches live longer, but I am sworn to secrecy!
What year truck do you have?
They make the Trans-go jr for the 06 and up Allison 6 speed. It has you replace some springs and check valves to increase line pressure. With this kit you do NOT have to take out the trans. :cool:
You will need to pull the trans and disasemble to properly install the Trans-go kit then.
Don't worry, the worst part is actually getting the trans out of the truck. Opening up the Allison is pretty simple, just take your time. Also, if you are considering the kit from Suncoast, They also offer a service manual for the Allison transmissions. I have one and it is a great resource. Suncoast stuff rocks!
Mike L. also has an excellent book called transmission times that I believe he and Trans-go made.
1 - 7 of 7 Posts
