1 - 2 of 2 Posts
When you guys have the fluid changed in your trannies do you have them plushed of do you just drop teh fluid in the pan and re fill that?
The mechanic says you should flush but so many people i've talked to with alison tranny's just drop teh pan. and then change the spin on every oil change.
How do you guys do it?
I drain it out of the plug in the pan and change the spin on. If you do it often (I go every other oil change) there doesn't seem to me to be any reason to pump it.
1 - 2 of 2 Posts
