ok so about a month ago i got the famous hole in the tcase. but i caught it befor it grenaded. i took out the tcase ripped it apart and ordered all parts needed. just installed it. now the cel is one and found all these codes in there
B2575
P0700
B2580
P0748
P0763
P0768
P0778
P0773
P2810
P0743
while i had the tcase out i got the efi live. hooked it up and copied the stock tunes and sent them off. havent flashed anything just hooked up and copied.
any clue what the hell happened? the trans ran fine befor i took the tcase off.
B2575
P0700
B2580
P0748
P0763
P0768
P0778
P0773
P2810
P0743
DTC B2575 Headlamp Control Circuit
DTC P0700 Transmission Control Module (TCM) Requested MIL Illumination
DTC B2580 Headlamp High Beam Control Circuit
DTC P0748 Pressure Control Solenoid Circuit Electrical
DTC P0763 Shift Solenoid (SS) 3 Control Circuit High Voltage
DTC P0768 Shift Solenoid (SS) 4 Control Circuit High Voltage
DTC PO778 Pressure Control Solenoid B Electrical
DTC P0773 Torque Converter Clutch (TCC) Enable Solenoid Control Circuit
DTC P2810 G Solenoid Circuit
DTC PO743 Torque Converter Clutch PWM Solenoid Circuit Electrical
MAYBE THIS WILL HELP id check the transmission connector check cut or chaffed wires
are the codes current fail or pass fail
yeah the connector was not in all the way. the clip inside came out and wouldnt let me put it in all the way. but its fixed. took it for a test drive and the right rear caliper lockedd up and caught the brakes on fire. took out the wheel seal. blah blah blah. so yeah yay me cheers
