1 - 2 of 2 Posts
I have a 2007.5 (new style) GMC 2500HD 4X4. The transfer case shifter motor failed and I replaced it with a used one, the used one was tested and proven to be good. Once installed on my truck the t-case shifter motor will not work. Is there some programming that needs to be done before the motor is recognized and will operate?
Did you check to be sure you are getting voltage to it? A lot of cold climates aka in the salt belt are known to cause electrical problems with electronic transfer cases. Corroded connectors and wires are the most common.
1 - 2 of 2 Posts
