Finally had a local transmission company pull my transfer case and open it up with only 38k on my odometer. They called me today and said the chain and several sprockets inside the transfer case are trashed.
Said they don't normally see this kind of damage, especially with only 38k on the odometer, but this is the first 2017-2019 L5P transfer case they have opened up. (they also said it is basically an MP1626XHD model transfer case with some upgrades parts ... so they are very familiar this transfer case and have rebuilt hundreds of similar transfer cases, just not this new)
I told them to take pictures and forward me the parts list ... and let me know what they think caused the damage when they take it apart. (part failure, improper assembly, etc.)
Backstory
My truck has had a vibration in 4wd under load (when accelerating) since I purchased it brand new off the Chevrolet lot (September 2018).
Therefore this is an ongoing concern which I brought up to the dealer during multiple visits to their service department at ~12k, ~24k, & ~37k ... basically each winter when I once again used 4wd.
I even have the documented proof (warranty invoices) proving the truck was brought into the local dealer multiple times regarding the vibration complaint, including before any aftermarket parts were installed on the truck. (lift kit was installed at ~26k, after the first two warranty complaint visits)
The first two times I took it to the dealer they gave it back to me and told me these trucks are just noisy in 4wd. I believe the second time I brought it in they actually checked the front driveline for play and said it was within spec ... but unfortunately they never did run the truck in 4wd under load while up in the air and listen to the transfer case with a stethoscope (which I actually asked them to do). The third and fairly recent visit to the dealer they said there may be something wrong with the transfer case but they can no longer look at it under warranty because the truck now has a 4 inch lift kit on it.
Again, I have all of this documented on warranty inspection invoices from this local Chevrolet dealer.
I was however able to finally get a case number out of GM customer service today and an email where to send the pictures for review.
However, I am not getting my hopes up that GM will even reimburse me for this out-of-pocket expense, which should truly be covered under the 100k powertrain warranty.
Luckily the lift kit I purchased also offered a powertrain warranty if GM does not cover the repair, so I got lucky because I am covered regarding any out-of-pocket expenses on this transfer case repair.
Apologize I don't have the pictures of the transfer case internal parts failures from the transmission shop yet, but I will follow up this post with the pictures as soon as I receive them (hopefully tomorrow).
So for all of you out there with similar pictures to mine regarding excessive amounts of metal on your transfer case magnetic drain plug when changing the fluid ... beware ... you could have a major powertrain failure on your hands just like mine.
Pictures below are at 25k & 35k miles when changing the transfer case fluid ... according to the local Chevrolet dealer ... this is normal ... LOL.
Backstory
