my transmission went out and looking at putting a used one in i found one from an 03 and wanting to know if that will work in an 02 i know the 01 and 02 are the same but not sure if an 03 will work thanks for your help (allison)
Yes the 03 will work in the 02, but you will need the 02 NSBU switch, and adapters for the coolant fittings [Available from GM]. The 03 may have the "G" valve, but the 02 TCM will not look for it, it will not set a code.
Moved to Trans -- not a 911 problem
