I have an 03 Duramax with a recently rebuilt allison.It has a new billit tourqe converter, upgraded valvebody,high friction clutches,and rebuilt silenoids. It also has a TTI programer,airraid cold air induction with a ram air hood. It makes in access of 500 hp.The tranny holds good 1st thru 4th but in overdrive at about 70-75 if you began to accelerate at half throttle it slips and shift range prohibitted appeares downshifting to 4th. The check engine light appears with code P0735 which is incorrect 5th gear ratio. I was wondering if one of the pressure silonoids or tourqe converter might be the problem?:help
