i have a 2007 lmm an i keep getting P0700 codes while idling warming up in the morning,have to clear the codes off before i can drive, its good all day after the codes are cleared, i got transmission fluid pressure sensor A circuits, stuck selenoids, transmission components slipping. an drives perfect every time after codes are cleared, i was having stuck selonoid c before an i got a built tranny now with a precision triple lock torque converter, red alto discs, an the transgo shift kit, ran good all summer was anywhere from stage five to seven on the edge, hauled trailers on lower settings never an issue, tranny runs cool, but when it got cold in the mornings the codes started popping up, getting real annoyed with it, after i changed the tranny fluid an filters it seemed to be good for two days, then back to same thing, heard about the ignition switch might be sending low voltage is this actually a fix i dont wanna be throwing money around at it for no reason, last couple weeks my old mans stock 07 started doing the same thing :help
