I have an 03 duramax and I've noticed a drop or two under the truck after sitting for a day or two. So I climbed under thinking it was pan gasket but after a I cleaned it all and let it sit I noticed it starting too show moisture from the bottom of the harness plug that connects too the inner harness so I was wondering if there is just a o ring I can replace or do i have too order a new plug or whole new harness?
1077583
Seal is easy to replace. Google “Allison pass thru connector seal”
I have an 03 duramax and I've noticed a drop or two under the truck after sitting for a day or two. So I climbed under thinking it was pan gasket but after a I cleaned it all and let it sit I noticed it starting too show moisture from the bottom of the harness plug that connects too the inner harness so I was wondering if there is just a o ring I can replace or do i have too order a new plug or whole new harness? View attachment 1077583 View attachment 1077583
Awesome! Thank you
