1 - 9 of 9 Posts
So , I think I hurt my truck tonight .
Under decent acceleration , hit 65-70 mph and was like it hit neutral for a second and then went back down into 4th and stayed there and the MIL came on as well . I checked the codes (going by memory here) P0700 - MIL request and I can't remember the other code number but the description was Control Pressure Solenoid A stuck open . I cleared the codes , got back out on the road and it seemed fine through all gears under the same acceleration as previously attempted , up the highway a little further I gave her a little squeeze again and the same thing , dropped a gear and MIL comes on . This time it was the P0700 - MIL requested and a P0735 - Gear 5 Incorrect Ratio .
Is this indeed the dreaded limp I have read about ?
Yes indeed, that my friend is limping your transmission. Be easy on it in the 4-5 up shift and 5-4 down shift. Also don't get on it hard in 5th gear as it sounds like you were doing. Now that it's been limped it will be easier to limp again. How big of a tune were you on when it limped?
90 hp
I guess the next question is what kit I need to put into it .
Best bang for the buck kit , I don't ever plan on making a 1000 hp , but I wouldn't making making more than what I have now maybe down the road and I like doing a job only once .
Any recommendations ?
Call Andrew @ suncoast
Can be slipping clutches--- or caused by the transfer case -- speed sensor-- or worn transfer case. Pull the drain plug from the TC --see if it has metal in the oil.
Discussion Starter · #7 · (Edited)
Not doubting you jc1843, but can you explain how the t-case can be the culprit ?
Is there clutches in there that can slip ? I have heard of the pump rub issue but I thought that would cause a loss of fluid and the destruction of the t-case . Or is it filings on the sensor throwing the reading out ?
The P0735 code is set when the output speed does not match the input speed expected by the TCM.
The speed sensor is located in the rear of the transfer case. The TCM does not know the difference --Trans or Transfer case.
So you are saying that the slippage can be in either the tranny or transfer case ?
Or metal shavings can cause the reading of the transfer case speed sensor to get a little scoogey ?
I'm pretty sure that given the circumstances , something slipped .
1 - 9 of 9 Posts
