Have 5000 miles on my 2011 and want to change out the trans fluid and go with Transyn or Mobil Del Vac. Would do the 2 change method so would need around 4 gallons. Where is the best place to buy either fluid in or around Northern Cal? Also a vendor for the deep pan for the Allison. Thanks
You might check around and see if there is a Allison dealer in your town. They work on the large truck trannys as a factory type dealer. I get Transynd from the local Allison shop here for $32 a gallon.
could u use transyd from a 5ton allison on my truck if so how many litres
Pretty sure tansynd is for all Allison's. Not sure on the capacities. Check Allison's website.
Sent from my Autoguide iPad app
