I've been having electrical issues for quite some time. The truck is a 2001 GMC with the LB7. Put in the Banks Six Gun right when it came out... No PDA, just the plain unit less the speed loader.
Over the years, we've had the following issues:
Driver seat harness burned out
Driver window motor failed
Horn failed - again after replacing the relay
Radio mysteriously stops occasionally - like power has been lost to it, yet miraculously recovers at its own convenience
Keyless no longer works
Most recently, I've noticed that when I turn on the passenger dome light, the cargo lamp indicator comes on briefly. weird.
So, today, I pulled the Banks unit. Truck runs great (though stock) but the engine light came on. Scanned as
P0236 - The PCM has determined that the input voltage for boost pressure sensor "A" is out of range for the current engine operating conditions.
Whats this mean? Can I just clear it?
Thanks
oh yea... the cargo dome indicator does not come on anymore - go figure.
would check for aircharge cooler line leak listen for wistles hisses. if none found clear code and check for reacurance of code.
I cant hear any leaks, and its running great. For some reason I didnt even bother to ask if the guy at AutoZone can clear the code... Do they have the ability to with those handheld units they use?
Also... The passenger door stopped unlocking itself w while ago when you put it into park.... problem solved as of today.
I don't know if auto zone can but dealer can for sure so talk to them
Auto Zone can but most of the time they won't for sme reason.
