1 - 8 of 8 Posts
i have been noticed that my truck has been taking longer than usual to start sometimes.. i recently just replaced my starter and batteries. and sometimes my truck starts then dies... any ideas?
I'd suspect possible air in the fuel lines
Pump the primer button, before you try to start-- if that helps, you probably need to rebuild the filter housing-- it is sucking air.
I had a similar problem and the fuel filter housing had a crack in it .
1 - 8 of 8 Posts
