Guys, truck has 120k on it. I put the cat filter and adapter on it 4 months ago. It's been running fine until today. Bought the primer rebuild kit and replaced everything.
Prime it and fuel and air bubbles out. I think I primed all air out.
Tried to restart, idles and then dies after 10 secs.
Should I put stock filter back on?????
Changing back to the stock filter will be a cheap way to either eliminate or validate a problem with the aftermarket model.
LHN...We ARE the Joneses
Stock TP3018 has better filtration specs, and water protection. Kitty adapt is going backwards in the quest for the best fuel protection.
It can be a leak source also, but keep in mind that not all potential leak areas with the filter head are serviceable with the 6-pc rebuild kit.
Remove the inlet line (arrow on top) and hold your finger over the tube, pump the primer, see if it pulls a vacuum, and how long it holds. If it leaks off, remove the adapter and try again.
You may find you need a new filter head. Also, when it's time to address the filter head leaking, it's also time to replace the two lines to/fro it with bio fuel compatible 1/2" bulk fuel line, as the stock ones are weak, cracking, and prone to suck flat and leak.
THank you guys!
Bought a new Carquest filter (USA made) because the local Advance didn't have AC Delco in stock. Also bought a new water in fuel sensor since i threw the old one away.
Cranked it 3-4 times and she fired up!! You guys are right, the kitty filter isnt a good solution.
