1 - 8 of 8 Posts
2003 LB7. When truck sits over night is the only time I have noticed this problem. Truck fires right up as it should. Idles for about two seconds then dies, and won't start after that. The fix for this problem is to prime the fuel filter. After filter is primed truck starts and runs perfect.
Sounds like your filter housing could use a rebuild. Or maybe invest an AD II instead!
not to steal this thread but when you add an air dog do you remove the factory fuel filter and housing
you can but i still use mine . i like having the extra filter , can't get the fuel to clean
thats good dont want to remove it if i dont have to.
what is involved in a rebuild. DIY or send out, dealer.
The rebuild kit is like 30 bucks or so and is a DIY, takes about 30 mins. It's just a few o-rings
awesome, thanks for the help.
1 - 8 of 8 Posts
