1 - 8 of 8 Posts
2022 Midnight Edition Ltz 2500hd
So my truck shuts off periodicly. The dealer is telling me they cant do anything for me and to bring back it back when it happens again so i dont have alot of ignition cycles. Do these codes look familiar to anyone. The first code is whats shutting the truck off. Thanks
so i was towing my snowmobile trailer and the truck was acting funny. Then on the way home today it was acting worse. i then got a bunch of messages. Engine power was reduced check engine light came on. Then i got text message service the engine and transmission system in my truck within 1 day. Im not looking forward to what is going on with this truck. have an apt monday
Im being told that cant try to fix the one issue until there is an active code. Does this make sense? Like where do they the code came from? Guess im calling chevy direct.
When your check engine light comes on, that means that the ECM has stored a fault code. By the time you got to the dealer, it may no longer be active but I believe it should still be there in history, unless you cleared it. . And yes, it's very true, that when you have an electrical problem that is not currently acting up, you just have a normally functioning electrical system. You have to identify exactly where the problem is occurring - what is the cause of the problem. You recorded what the codes were so that's good, but the tech can't see the problem because they are no longer occurring. If you told the tech to keep checking - you'll pay for all the hours it takes to fix it - you may be a poor man soon.
At this point, and to save you money (if you care about that), keep driving until the codes come up again and do not clear them. When codes are created they also create a file of collected data points when the problem occurred and that may help a tech to find the solution.
Reactions: wydopen731
The first dealer i went got the active code and wouldnt work on it. So when it went to the second dealer the code was cleared but i had the print out. Again my question is whats the point of a code if their not gonna inquire, also is it safe to send a truck out that stalls on its own just so the code can become active again?
1 - 8 of 8 Posts
