1 - 16 of 16 Posts
Whats the weight of my 2005 crew cab short bed 4wd duramax? Looking at a lift and dont know how much my truck weighs!!
Mine isnt crew cab, but my extended cab with full replacement bumpers front and rear with half a tank of fuel and myself ( about 145) was 7120 I wanna say..... Just to give you an idea....
I am getting ready to get 9000 lb lift for my shop. I may get a 10000 lb if I can.
the lift i'm looking at is a used eagle 9000# for $1,000. Just dont know if its big enough?
Anybody curentley using a 9000 lb lift on a ccsb 4x4 duramax?
I think it depends on what your use for the lift is. I know guys who routinely use their trucks for work and they keep a 1000 lbs of tools and equipment on the truck. If you are not loading your truck that heavily 9000 lb should be fine.
Yep half tank of fuel scaled it few times over the years.
ok, It should work for me then. my truck is empty most the time. Is a eagle lift worth $1,000 used?
I have a 06 ccsb 4x4 and with myself and bout half tank of fuel weighed in at 7120 on the scale. A 9000 would be close but should be alright
$1,000 it won't last long! I'd snag it if I had the chance.
I see new ones for $1500 to $2000 depending on options. Depending on options (multiple vehicle adapters) and condition $1000 is probably not bad.
i recently ran my 04 CCSB across a scale up in canada and it weighed out at 7700# with a half tank of fuel and 1 passenger
Mines 7000 also
1 - 16 of 16 Posts
