hey guys new to the site....i have a 2003 lb7 and was looking to get an efi live tune from duramaxtuner and a 5 position dsp5 switch.
what is necessary as far as a monitor? i know i need to see egt and boost. i will be pulling a 30 ft. 5th wheel camper.
is this the right way to go. an efi live, switch, boost valve, and a monitor?
i would like to start building my truck but also this is a daily driver..will the
80 and 100 hp. tune be enough?
whats the next step to do for aftermarket power. example tranny ? injectors?
and how much.....
thanks guys hope this isnt too much to ask all at once.....thanks
new diesel owner needing advice......
You are on the right track, however in my opinion I would do a 120 or possibly a 150 tune if you ever plan on upgrading your trans. With that said, I would definetly recommend alligators kit for a transmission. In regards to injectors you will not need bigger unless you plan on upgrading your turbo later on, if your injectors go then I would upgrade. Lastly you will definetly be needing a lift pump to get that extra filtration.
Sent from AutoGuide.com App
