My 2004.5 LLY has been a great truck for the last 104k, hopefully this is a quick fix! I have done all the maintenance and work to date, but I wanted to find out if I am on the right track for this issue?
With the exception of an LBZ mouthpiece and Banks PowerPDA the truck is stock.
When this first started it would intermittently throw P0046, I would reset and the truck would run great. Now the truck is continually sluggish and throws a combination of P0046 and P2563. When I get on it the truck spools up slowly and irregularly and eventually makes a "BWhrr..BWhrr..BWhrr.." sound and hesitates a bit.
Reading through other forum members posts, I see similar problems, but never a summary of what eventually fixed the problem. The only options I see are new Vane Position Sensor, Vane Actuator, Wiring issue, or new Turbo. I pulled the Banks out of the wiring harness and still see the same issue, without the ability to reset codes.
Is there a way to narrow this down without shotgunning it like a dealer? My thought is that the Sensor is the easiest to replace and the most likely culprit, is there a way I can confirm this?
Thanks!
765175-0010
Thanks!
765175-0010
